ecu's
    ecu's
    which onw would be the best ecu the f22a6 ecu or the p12 ecu
    for... what motor?
    COUPE K24
      For what setup/engine?
      02 Crv
        PT6 is best for the F22A6, or an F22A1/4 running the A6 intake manifold and camshaft.
        P12 is best for a stock F22A1. The P12 does not control the IAB.
          oh my bad its a F22a1 soon to be with h23 IM
            Welp if you want the IAB's to function like their supposed to then the pt6 is what your after.
            02 Crv
              pt6 is from wat the F22a6 right
                Deev's done covered that, but yes F22A6=PT6 ecu
                02 Crv
                  ok thanks for the help
                    not to thread jack but the iab's are what?
                    and say i dont have the pt-6 how would that affect me? i thought it was for noise reduction. or maybe that was just a part of it.
                    Accord SE
                    93se
                    Members Ride
                    Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
                    Sold to: sulimed, BurtonRiderT6, tishock
                      Noise reduction? What do you mean?
                      IAB is the "secondary runner" system in the F22A6 and H22/H23 intake manifold design.
                        Intake Air bypass at a certain Rpm the secondary butterflies open.
                        02 Crv
                          something to do with when they open at a certian rpm and close at a certain rpm that reduces the noise? i could have just read wrong. but what is the point of the secondary runner system i guess is what im asking when i asked what does it do?
                          another question i have is if there i guess left open wouldnt that help by allowing air flow?
                          sry i prob just dont understand the function at all. lol
                          Accord SE
                          93se
                          Members Ride
                            Basically at higher RPM's it throws more air into the engine when it needs it hints the intake tone that changes at 4600-4800 on these F22A6's or F22A's with a IAB intake swap.Theres lots of debates on the subject most can be found on this site.Weither to delete them,run them off vaccum etc etc.
                            02 Crv
                              The intake air bypass is used to maintain a certain length runner at different RPMs. It's a sort of resonance tuned adjustable length intake. Longer runners help maintain tq in the lower RPM where as the shorter runners are better for the higher RPM.
                              Running with them open all the time (or plates removed) just means that your running a shorter intake runner and loosing out on some low end tq. However, the but dyno usually substitutes the more aggressive sound and quicker throttle response to more tq. When there is not!
                              MR Thread
                              GhostAccord 2.4L Blog
                              by Chappy, on Flickr
