I have a code 8 on my tcm. What does that mean?
tcm code 8
its your shift solenoid B.it needs changed ..
If everything is working perfectly, reset the TCU (pull the radio/backup fuse, and/or disconnect the battery for 15-30 minutes.) It may not be a current code. You could also inspect the TCU for damage, as they do occasionally get burnt, causing problems, or reporting problems that don't exist.
Or, possibly, it's reporting a problem that hasn't manifested itself noticeably yet.
Originally posted by stretch JDM View Postits your shift solenoid B.it needs changed ..
Originally posted by deevergote View PostIf everything is working perfectly, reset the TCU (pull the radio/backup fuse, and/or disconnect the battery for 15-30 minutes.) It may not be a current code. You could also inspect the TCU for damage, as they do occasionally get burnt, causing problems, or reporting problems that don't exist.
What's with the current trend of omitting "to be"? I keep seeing "needs changed", "needs replaced", "needs washed". It baffles me.
If I am getting the code and the flashing S light I can click my key off and click it back on when I am driving and it will go off then just come back on
