soooooo a P0b wont plug into a cb7 harness???????
    so what truth is there to this
    :Using a 94/95 Accord ECU (P0A/P0B)? Swap pin A6 with A11 on the ECU harness. This is necessary since the 5th gen was wired opposite of the 4th gen for these two pins.
    it was on this forum http://mycb7.com/bb/viewtopic.php?t=771
    im just asking because i have a P0B laying around and when i opened it no bull$h!t it had a spoon sticker on a chip that you could pull out email me for a pic if you want to see it lol no joke
    It should plug in just fine. As far as I know, all OBD1 Honda ECUs will plug in. I have a P28 in my own car.
    That Spoon chip, however authentic it may be (or not... I don't believe Spoon EVER offered chips for the F22B2 [which is what the P0B runs, I believe.] Or the F22B1 [P0A, I know that for sure.]) won't do a damn thing for an F22A. It may run, but it won't be beneficial... and may even do damage.
    And why did you link to a 4 year old H22 swap thread?
      If it is a obd1 ecu which it is by going by your info it should work. All obd1 Honda ecu plugs are the same. But as far as the pin info I can't help you.
      STANCE|WORKS
        Just wanted To know if it would plug in and let the. CB7 run at all with the pin swap when it was plugged into the CD7(which was the way I got the free car) after the swap it would only let it rev to 4k then it would fall on its face I had to individually wire the vtec in to the p0a and now she runs fine just have the "chipped" p0b here taking up space and noone wants it can't let it just go to waist
          wut?
