H23 Swap?
    Yeah, do what you need to do to the H23, drop it in there, leave it stock, and get to work on that F22. Sleeve it, install forged internals, and build a turbo setup that will make the power you want. Tune it carefully, maintain it properly, and it SHOULD last. Try to avoid boosting on stock internals (all the H and F engines will eventually break a ringland, even in the most capable hands... it's just not built to hold boost.)
      Yeah, that sounds like a plan. I kinda wanted to do a DSM turbo setup on stock internals, and upgrade it as I go, but the thought of it not lasting very long bugged me a lot.
      Plus I have the mind set to do things right, just usually not the budget for it. So I think with the motor out it will let me put money into it and not worry about reliability of my DD will make it easier.
      PSN
      Vash744
      MRT 1992 EX Coupe "The Jerk"
      2009 Subaru Impreza 2.5i Premium Hatchback
      2008 Honda Fit Sport (Totaled out - Death by fallen tree)
      1993 CB7 Sedan LX (Totaled out)
      1991 CB7 Sedan EX (Dead and Junked)
        Yeah... with stock internals, especially if you're rather new at turbo... upgrading as you go would probably involve getting a block that doesn't have a huge hole in the side of it from a thrown rod...
          So i guess the question to ask is:
          Which motor is better for boost? the H23 or the F22? Wouldn't the long stroke of the h23 be better for boost?
          PSN
          Vash744
            They have the same stroke, 95mm. The H23 has a larger bore.
            Either is fine for boost if you resleeve and use forged internals. If you want to go cheap, the F22's iron sleeves are compatible with many more forged pistons than the H23's FRM sleeves (compatible only with Mahle Gold Series pistons, and MAYBE some pricey options from Cosworth and JUN... they never replied to me when I asked, so I can't say for sure.)
            Both in stock form... they're about the same. The healthier of the two will be the best option, but it won't last long.
              Ahh I see. Well Sounds like a good deal with me! Thanks for all the advise Deev!
              PSN
              Vash744
