recently Ive started working on my brothers car
we got it about 2 years ago but never really cared to fix it up since my coupe is the tuner car
HOWEVER recently we decide that if we r gonna keep we r gonna fix it up
so here is what was wrong with it
when we first test drove it we noticed that it over heated and there was strong fumes coming out from the AC vents., i noticed a radiator leak and assumed that was the issue so we bought it anyway since it was fairly cheap.
after we bought it we fixed the leak without having to replace the whole radiator so that was good and then we left it like that for about a year, other than one oil change and new spark plugs we didn't do anything to it cause we assumed that the engine was as good as it was gonna get.
after we decided we were gonna fix it up we took a closer look at the engine, by that time the check engine light was on, after pulling the codes we discovered we needed a EGR valve, so we went to the junk yard and took about 3, we cleaned all the carbon out of them and tested to see witch would work best, this process lead us to a conclusion that based on our EGR valve our entire intake manifold was VERY carbonized.
well after replacing the EGR valve the check engine light turned off and that was that.
STEP 2 cleaning the engine
using Lucas we decided to do monthly oil changes until all the gunk was gone, the first time hardly any gunk came out but the oil was very dirty, the second oil change was the jackpot, ALL the nasty shit came out, the oil was pitch black and super thick, that tune up changed the entire performance of the car, it ran allot better, shifted gears allot smoother
since then we have done 1 more oil change, changed spark plugs AND wires, and cleaned out the whole radiator to replaced the water with 50/50
SO NOW
*we are having the same problem with the fumes coming thru the AC vents
*it shifts a little stiff
and it over heats when we drive slowly, or are on idle (tho not all the time)
my theory:
i believe that replacing the intake manifold might get rid of the fumes.
i think that the air just needs to flow better thru the engine.
and if it helps maybe change the entire exhaust system (headers, down pipe, muffler...) and add a better cold air intake
my dad thinks that the problem might be the down pipe or exhaust.
my mom got my bro a full audio system, brand new speakers, and cd/ ipod player AND she painted his car so its looking very good, i have a few lips in storage that ill let him pick from.
but first we need to fix the engine
i mainly wanna fix the over heating and fumes.
ANY OPINIONS?
SO NOW
my theory:
ANY OPINIONS?
