the seals under the valve cover.i took my car to the honda shop and they told me this.if this is true what can it cause to happen?i already bought the kit for the spark plug tube seals and the valve cover gasket.thanks
symptons of oil in spark plug tube seals
If I understand your post correctly, you need to replace both the o rings in the valve cover and the o rings under the rocker arm assembly, both of those sets of o rings wear out and cause oil to foul your spark plugs.
The first one is a breeze, the second one is a little more involved and you need to adjust your valves after that. If you are looking to perform the service yourself, Eric The Car Guy has a video on how to replace the lower tube seals.
