Hey Everyone, Been a while since I have needed to ask any questions about my CB7. I can usually find the answer in this site without having to ask, which is great! One stop shopping for any problems I have had. So here we go. I pulled my EGR valve out and put in a block plate. Not worried about emissions cause I am in Florida and we don't have to worry about it. The car runs so much better since I did that! Couple extra horses is always good! Anyway check engine light is now on. Bug's the crap out of me. I know there is way I can either run a diode or connect 2 of the 3 wires together to fool the ECU into thinking the EGR valve is working. What is that combination? There are 3 different colors, Green, Yellow and White. Thanks in advance for everyone's help and input!
Installed EGR Block Plate
From the research I have done yes. As much as I hate ebay for my parts, I found the block plate there for around 7 bucks, milled aluminum and it works great! I think when I was looking at them they also had h22 available. I put in a re manufactured f22a6 last year and did some mods to the intake and throttle body while apart but failed to clean the ports out which resulted in poor performance a year later. But yes big diff in throttle response. Keep in mind your not putting exhaust back through the intake again, just clean air, when you block the EGR port off! cleaner air = better performance! LOL
Originally posted by Joewill2848 View PostJust wondering how this helps horsepower? I am not saying that you are incorrect just curious how that works. May be interested in doing that myself if I can. Does that work on the H22 head as well?
That's how it helps in theory anyway.Last edited by YourPartsGuy; 09-12-2011, 02:13 PM.
Yeah, I am thinking that the green wire is probably ground, which leaves the white and yellow. Logically speaking, if you connect the 2 wires together, that would complete the circuit and tell the ECU that the EGR is working. I just don't wanna blindly connect 2 wires together and fry my ecu! LOL
Originally posted by Tippey764 View PostMind you this only works on our obd1 hondas
Our cars don't detect egr flow, only if the valve opens and closes. So long as the valve opens on command it will work
It works on our cars but don't assume all cars. If you did this to a 91-95 acura legend it would actually blow the head gasket.
Originally posted by JSCB7 View PostFrom the research I have done yes. As much as I hate ebay for my parts, I found the block plate there for around 7 bucks, milled aluminum and it works great! I think when I was looking at them they also had h22 available. I put in a re manufactured f22a6 last year and did some mods to the intake and throttle body while apart but failed to clean the ports out which resulted in poor performance a year later. But yes big diff in throttle response. Keep in mind your not putting exhaust back through the intake again, just clean air, when you block the EGR port off! cleaner air = better performance! LOL
Bought from:AbsurdNY,92smokeaccord,cb7inct,nevi325,xkjnboix,cb 7resurrector,JoshM
MRT: http://www.cb7tuner.com/vbb/showthread.php?t=203451
Originally posted by cloudasc View PostSo if the egr ports fill up with carbon and arent cleaned regularly on a 91-95 acura legend it could blow the headgasket
The ECU on the legend is more advanced than ours
When it enables the EGR valve it can actually adjust timing as much 10 degrees and lean the fuel mixture out 5-10% to account for the exhaust gases in the cylinder so it can maintain performance
When the EGR passage way clogs the ECU does not know this so it still adjusts timing and reduces fuel but since there isn't exhaust gases it causes severe detonation in the cylinder which slowly blows the head gasket.
