HI everyone.
My rear suspension is making a clunjk/rattle when i go over bumps. It sounds like its coming from the right side.
If I go down a dirt road it sounds like it's about to fall apart.
I've replaced both control arm bushings, and the strut on the right hand side. All new parts except for the bottom rubber piece that goes between the strut and the spring.
I haven't replaced the left strut yet. The bolt the mounts it to the knuckle is seized. Both of those bushing look like they could use replacing. I have them on order and will get them in sometime this week.
When I did the passenger side rear forward control arm (the toe in one) I accidentally bent the (subframe) piece of metal that goes across from wheel to wheel. (Not a sawy bar). I bent it back and had it aligned. Still makes the noise.
I haven't replaced the trailing arm bushings, and I'm not sure how. I think Hardline.com sells them, but I haven't called to confirm.
My question is this: Once I get these lower bushings done, and the left side strut, what else is there to replace if the problem remains?
