Low or High Compression for N/A Build ?
    I'm wanting to sleeve my H22 block with Darton MID Sleeves and upgrade to Wiseco Forged Pistons and Eagle Rods . I plan to keep the motor N/A , no boost . I need to know is a better to keep a high compression for a N/A build so I know what bore size to order the sleeves and pistons . The standard bore size for the H22 is 87mm correct ?
    87mm is correct IIRC. Definitely high compression for all motor. Comp ratio of your choice. Big thing is tuning. Don't want to slack on tuning. Before buying anything, set a goal of what you are looking for. What HP are you wanting to make....budget....any other factors that may come into play.
    H23A-powered CB7 coming soon.....
      if going sleeved and NA, id probably goto a larger bore. at least a 89mm
