ok im a noob to the honda world i have a 90 cb7 with dookie ebay coilovers and my bumpstops are cut to only one ring about half an inch i was wonder what other stock parts off other hondas i could use to go lower (my ride pretty much sucks anyways )
wanting to slam my cb7
Just because your ride sucks doesn't mean make it suck even more. Them cheapo sleeves are bullshit (and I'm assuming you're probably riding on stock struts which compounds the bullshit). I'm not sure what u could use off of another Honda suspension wise to lower your shit more. I'm not sure why u would even want to use another Honda's parts, just stick with CB parts. Apparently safety to yourself and to others isn't a primary concern, how low are u trying to go anyways?
For the height you want to go, and for the insanely high spring rate those cheap shit sleeves have... no. I already gave you your cheapest option.
If you can't afford to lower your car safely, you can't afford to lower your car. It will take a minimum of $500 to lower a car safely, and to "slam" it, you're going to need to spend about $700-$800.
Originally posted by flatblackcb7 View Postok call me cheap but those teins are a little out of my price range, is there any cheaper route maybe a decent strut that i can run my sleeves on ?
so as i do agree with all these statements there are ways around this without spending a bout load of money...but your ride is going to suffer and then your lower back and then your going to be in a wheel chair anyways......
i did somesearching for an equivalant coil over(a real coilover not ebay sleeves) to raceland coilovers which we would use in the vw community....and did come across a set for $350 out of your price range or not that would be the way to go. but the stiffness you may get from a 700 coilover kit is going to go out the window. so expects a bouncier ride as if you had 2inch lowering springs on old stock struts....
and i do now own a cb7 90 f22 5spd lowered on ebay sleeves(not to happy about that how i got it) and tokico blue struts and 94 rims with 205 45 hankooks custom flowmaster exhaust k&n intake front and rear strut bars clear euro turns corners and smoked euro headlights. painted jet blck with a respectably clean red/brown interiorand an acura tl lip. 20% tint
Originally posted by flatblackcb7 View Postabout using control arms off of a hatch or somethin like that but could never find it again
Member's Ride Thread
Originally posted by mercyboyI'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
