first off i wanted to say I did not come here just to ask for help on my car. ever since i got my car (and first started noticing how many others were still on the road) I have kept an eye out for them. I came here mainly to have others with the same car as me to hang out with, learn from and perhaps even share my knowledge.
i have a 92 Accord 2.2L EX with an automatic transmission. 2 and a half weeks ago (August the 21st (Sunday)) the D4 light started flashing GREEN. I also had a major fluid loss as well as shifting problems. I put fluid in twice that day and it hasn't lost any fluid again since (i check it every day) and for the most part has shifted fine until this past Saturday.
I called my Honda friend that i used to work with and he said 2 things. 1) the transmission was gone 2) to pull the "back up" fuse to reset the codes and see if they came back on and was going to look up the codes for me when he went to work. the same week on Friday the light started flashing again. i pulled the codes that time and found a site that had a list of codes. i had 2 codes. according to the list i found my 2 codes are the following: 7 -Shift Solenoid 'A' circuit open or shorted. 15 -Kick down switch circuit shorted. now i had to look up what a Kick Down switch did. i know where the shift solenoids are and what they do. at first i thought maybe they were shorting off each other. i could only manually shift the car and it still flaked out sometimes going into second and third. putting it into D4 it wouldn't shift at all on it's own. i pulled the "back up" fuse again to reset it and now it shifts fine again. if it was something other then the TCU would it reset it self twice by pulling the back up fuse?
this was the second time i had a shifting problem. coming up on a year ago i replaced the TCU due to a no shifting problem. the GREEN light around D4 just stayed on no matter what gear i was in. i put a used TCU into the car. in searching on the internet, i have found that the TCU's are usually the reason for shifting problems in these cars.
Resetting the codes temporarily fixes the problem for several days with no problem at all shifting. Could this shifting problem also be caused by the TCU?
Any assistance would be greatly appreciated. Thank you all so much in advance.
