When car is cold it bogs on 20% throttle
    Originally posted by thepowderblue View Post
    I dont have oil in the spark plugs.
    I put new wires on and I think that fixed it.
    The car seems to run better. It use to shake like I had bad mounts at idle but it does not do it anymore with my new wires
    I also rerouted them
    Schweet! Let us know if it comes back.
      What brand are the wires? (both the old ones and the ones you just put on?)
      Not that it really matters... just curious.
        The old one where belden and the "new ones" dont say. Kai gave them to me a few months ago but they look high quality .
        Green EX http://www.cb7tuner.com/vbb/showthread.php?t=176536
        93 SE http://www.cb7tuner.com/vbb/showthread.php?t=210486
          I've never seen a wire that didn't look high quality... the quality is what's on the inside.
          If the problem continues, I suggest getting NGK Blue wires, or Sumitomo wires from Honda (those are actually the best of all.)
            Well when you but those cheap copy's the tubes that go down in the spark hole are made different and alot cheaper, like the nicer ones have a boot on the bottom and there is a plastic tube that gos down. On the cheap ones its all rubber and theres no little boot and they never seal right at the top of the hole on the valve cover like the nicer ones so you can get water in there while washing your motor. Plus the wires feel stronger on the ones I got but thats just me. When I put them on I could feel them grab on to the plugs and make a good connection unlike cheap ones.
            All I run are ngk or Denso plugs and I try to do the same on wires.
