ECU part number compilation
    I started a list to see what is different about the ECU's in our cars
    If you have something that is not on the list then please contribute with your ecu part number. If it is then i don't need to know it
    The ecu part numbers missing are not listed online
    If you post your part number please include
    Year
    Trim level
    Transmission style
    Emissions spec ( either california,49 state or canada )
    Also i would like to get canadian part numbers too.
    Here is my current incomplete list
    Here is a breakdown of what the numbers mean
    37820-pt2-000 : This is the part number for ANY honda ecu.
    37820-pt2-000 : This defines the engines general performance
    37820-pt2-000 : This digit means what region it was for
    The list below is for acura legend ECU's but i have not seen any ECU fall outside of its definition
    A: USDM Federal Emmissions
    L: USDM California Emmissions
    C: CDM Canadian
    G/E/F/S: EDM European
    0/9/J: JDM Japanese
    Y: Gulf Spec
    Q: Austrailian Spec
    37820-pt2-000 : This code seems to change with trim level, transmission type and body style. 0-4 are for manual ECU's and 5-9 are for automatic ECU's
    37820-pt2-000 : This code is for minor revisions from year to year.
    Automatic
    1990 DX 37820-PT3-A52
    1990 LX 37820-PT3-A52
    1990 EX
    1991 DX 37820-PT3-A53
    1991 LX 37820-PT3-A53
    1991 EX 37820-PT3-A73
    1991 SE
    1992 DX 37820-PT3-A56
    1992 LX 37820-PT3-A56
    1992 EX
    1993 DX 37820-PT3-A56
    1993 LX 37820-PT3-A56
    1993 AE 37820-PT3-A56
    1993 EX
    1993 SE
    Manual
    1990 DX 37820-PT3-A02
    1990 LX 37820-PT3-A02
    1990 EX
    1991 DX 37820-PT3-A03
    1991 LX 37820-PT3-A03
    1991 EX 37820-PT3-A23
    1991 SE
    1992 DX
    1992 LX
    1992 EX 37820-PT6-A12
    1993 DX
    1993 LX
    1993 EX 37820-PT6-A12
    California automatic
    1990 DX 37820-PT3-L52
    1990 LX 37820-PT3-L52
    1990 EX 37820-PT3-L72
    1991 DX 37820-PT3-L53
    1991 LX 37820-PT3-L53
    1991 EX
    1991 SE
    1992 DX 37820-PT3-L05
    1992 LX 37820-PT3-L05
    1992 EX
    1993 DX
    1993 LX
    1993 AE
    1993 EX
    1993 SE
    California Manual
    1990 DX
    1990 LX
    1990 EX 37820-PT3-L22
    1991 DX 37820-PT3-L03
    1991 LX 37820-PT3-L03
    1991 EX 37820-PT3-L23
    1991 SE
    1992 DX
    1992 LX
    1992 EX 37820-PT6-L12
    1993 DX 37820-PT3-L05
    1993 LX 37820-PT3-L05
    1993 EX 37820-PT6-L12
    Wagon automatic
    1991 LX 37820-PT3-A60
    1991 EX
    1992 LX 37820-PT3-A63
    1992 EX
    1993 LX 37820-PT3-A63
    1993 EX
    Wagon manual
    1991 LX
    1991 EX
    1992 LX 37820-PT3-A12
    1993 LX 37820-PT3-A12
    Wagon automatic california
    1991 LX 37820-PT3-L60
    1991 EX
    1992 LX 37820-PT3-L62
    1992 EX
    1993 LX 37820-PT3-L62
    1993 EX
    Wagon manual california
    1991 LX
    1991 EX
    1992 LX 37820-PT3-L12
    1993 LX 37820-PT3-L12
    1992-1996 prelude S
    Automatic
    1992 37820-P12-A51
    1993 37820-P12-A51
    1994 37820-P12-A52
    1995 37820-P12-A52
    1996 37820-P12-A70
    manual
    1992 37820-P12-A01
    1993 37820-P12-A01
    1994 37820-P12-A02
    1995 37820-P12-A02
    1996
    1992-1996 prelude S California
    Automatic
    1992 37820-P12-L51
    1993 37820-P12-L51
    1994 37820-P12-A52
    1995 37820-P12-A52
    1996 37820-P12-A70
    manual
    1992 37820-P12-L00
    1993 37820-P12-L01
    1994 37820-P12-A02
    1995 37820-P12-A02
    1996
    Some strange points i noticed
    Why is the 1991 LX wagon ECU different from the LX coupe/sedan ecu?
    Why is the 90/91 dx/lx pt3 different from the ex pt3 ( i hear the EX pt3 doesn't have a speed limiter since it came with proper speed rated tires )
    Why did California stop using California spec emission ECU's in 1994 with the prelude S?
      I can confirm this. My 1991 EX has seen up to 125 in its much younger days - no speed governor.
      Original-Owner 1991 Honda Accord
      2005 Acura TSX 6MT
      2010 Mazda Miata Grand Touring
        maybe the reason the 1991 wagon LX ecu is different is because it has different tires but still an f22a1? So maybe it doesn't have a speed governor either but for the a1.
        Does your ECU's part number match the one listed above?
          http://www.hondata.com/techecuid.html
          Originally posted by Hondata Website
          All Honda ECUs have a part number which is located on the side of the ECU and inside the ECU on the connector. e.g. 37820-P72-A01
          The part number consists of three components:
          Honda's part number for ECU, which is always 37820
          Three characters (which are loosely related to the model of car/engine). e.g P72
          Three characters (which are the revision of the ECU) e.g. A01 or G52
          The middle three characters are the most useful to identify what the ECU is. Different generation ECUs may use the same characters. e.g. a P72 OBD I ECU is different from a P72 OBD II ECU.
          The last 3 characters are broken down into 3 parts. "A" generally is used for US ECUs. "G" is European, and "J" is Japanese. There are other versions of this, but you get the idea. The second digit "0-4" typically means manual transmission, where a "5-9" means automatic transmission, and the last digit "1+" is the version number.
          The middle 3 digits are the main focus for engine performance. The last three are unit origin, transmission and version #. Don't think that the last digit has a big difference in performance of the vehicle. Unless it's an "L" = crappy California shyte. The version # is probably some components have been upgraded, or the board itself.
          MR Thread
          GhostAccord 2.4L Blog
          by Chappy, on Flickr
            The middle 3 digits are the main focus for engine performance. The last three are unit origin, transmission and version #. Don't think that the last digit has a big difference in performance of the vehicle more than some components may have been upgraded, or the board itself.
            updated the original post
            Thank you
            The very last digit can be a 0 though. The ecu i just bought has a 0 as the last digit
              True. I have had my 90Ex up to 140.
              So pt3 it normal performance on the a1,a4.
              And pt6 is higher performance for the A6 engine
              What does pt2 mean?
                What does pt2 mean?
                pt2 is for the f20a dohc
                There is also a pt5 ecu from a higher compression higher revving f22a3 in europe.
                Im going to post this link up as well
                Its interesting but not very usefull
                http://www.yudongguo.com/dList.asp?C...5%CF%B5&page=1
                  Now I want a F22A3. Or at least the head and pisions.
                  anyone have one
                    The member on this forum lindiz actually has one. You might be able to buy it from him if you were really interested since he just took it out
                    He told me it was a 9.5:1 compression.
                      Nice write up, Austin. Now I have to find the pic of my p12 out of curiousity.
                        anyone have one
                        Pistons would be a bonus if your looking for OEM cast pistons on the cheap. Head is probably a PT3 casting like the rest of the F22A* engines. Cam could be the same as the A6 as well. IMO the ECU would be the big pickup, if you needed to stay OEM.
                        Similar to the F22Z2 SOHC VTEC for the Accord 2.2i. It had 9.3:1 pistons and a different ECU tune. The head and valve train remained the same P0A parts. Could have possibly used the same pistons in this motor as the F22A3.
                        MR Thread
                          The f22a3 has flat top pistons. I bet the head might have a different cam then the a6 because of the higher compression and valve clearance but it very well could have the a6 cam. and it would HAVE TO HAVE stronger valve springs because it revs higher and has less piston clearance.
                            I have a PT5 in my 93 Accord which has a F20A8 9.5 comp
                            I Also have a PT3 in my 91 Accord which has a F20A4 9.5 comp
                            I dont recall the full number but both will be EDM spec.
                            UKDM 93 CB3 Page (1) H22A U2Q7 LSD
                            UKDM 91 4ws Page (3) OEM Minter
                            NOW H22A U2Q7 SWAPPED
                              Did it come with a pt3? Seems strange it would have the same ECU on a smaller motor.
