sputtering at highway speeds?
    So in the past week or 2 i've been getting a shoddy idle. itd bounce between 400-800 rpms, and i was occasionally throwing code 43.
    I did some reading and concluded that it was likely my o2 sensor, so I was gonna replace it this week (have to special order a Denso because everyone around here only carries Bosche.)
    I figured since the weather was nice out this weekend I'd go ahead and change the fuel filter as well. So changed the fuel filter, got everything back together, all seemed to run fine. idle no longer floating. steady 800rpm
    well this morning i was going to work pushing about 75mph down the interstate and i could feel the car bogging somewhat and start losing speed. I had to mash the gas to get it to pick up and start going, and when i'd go back to a steady throttle itd start acting up again. Got off the interstate and went on the service road. no throttle problems at all working through the gears or at 55mph.
    ideas? my car didnt throw the cel its been throwing this morning during the drive.
    You haven't replaced the o2 sensor yet, right? Bogging like that is most often an o2 issue, so that should fix it (the CEL doesn't always come on...mine didn't)
      not yet, i already ordered it, and was gonna replace it regardless if the fuel filter fixed the prob or not. just waiting for it to come in. Just wanted to make sure there wasnt another issue that may have popped up, and a forum search didnt provide much
      thanks
      added: also the sputtering just started, its not something thats happened before today. i guess the current o2 sensor could just be getting worse?
        It's most likely going to be fixed by the o2 sensor. I have heard EGR and MAP issues causing bogging as well, but they are less common, and they should throw different CEL codes. As you initially suspected, the code 43 is indeed an o2 sensor code.
          I do get the same problem with my car. If I am driving on the hw and keep my gas pedal steady my car will start to misfire bogging down. I have to push it harder for the problem to go away. even though there was no check engine light on, I checked it and I get code 1 and 12 which is o2 sensor and egr valve. It has do be the o2 sensor. Hopefully I get it fixed today
            update.
            i couldn't drive the car because it was bugging down a lot. i disconected the o2 sensor and drove like that for a while(wow what a difference).
            i replaced the o2 sensor and it was fine for a couple of hours, but then it started doing it again. it wasn't that bad like before but it has done it a few times.
            i replaced the o2 sensor so it doesn't have code 1 anymore. just code 12 which is the egr valve.
            as of now i am leaning towards a bad egr valve and clogged egr ports or/and a bad ECM
