PT6 ECU to replace PT3 - what will happen?
    I have all the components to place the A6 runners & IAB, H23 plenum & TB and PT6 ECU in my 90 Accord's F22A4.
    If I exchange only the PT6 ECU for my existing PT3 ECU first, and then don't get around to doing the other mods for a while, what will be the result?
    Will the PT6 adapt and the car will run ok? Run great? Run crappy?
    90 Accord Ex, F22A4. Slight fire damage.
    it will run the same, just you wont have a govener anymore
    miss my turbo cb7
      So the pt6 ecu is better then the pt3 I have a 92 with a f22a1 what ecu I have I want a better ecu
      1992 lx sedan-christy-my black beast
        you wont notice too much of a difference.
        I <3 G60.
          Just the pt6 has no gov cause if it don't I want that one
            Why, so you can go over 120mph in your 20 year old beat-to-shit family car on public roads with a maximum speed limit of 65/75 mph? That's a stupid fucking idea.
            The PT6 has a slightly different fuel map for the F22A6 camshaft, as well as controls for the IAB system in the intake manifold. These are things you can add to your F22A4, if you want an extra 10hp or so. It will run fine as it is on the PT6, though it won't be 100% perfect for what you have. Then again, the engine is 20 years old, so wear and tear make it less than perfect already.
