Fuse keeps blowing on factory fogs
    I have a 91 with factory fogs and they keep blowing the 15 amp fuse. They are all factory wired and the wires look fine! The only thing I have done to them is install piaa bulbs. Also does any one know if the fuse is supposed to be a 15 amp? Or should it be bigger?
    15 amp and when u changed the bulbs the positive wire is touching ground.. so take off ur bumber and fix the bulbs
    my new turbo build
      You know I took the bumper off and the fogs Out for the second time and you were rite they were grounding out!!! So props too you!! You called it. Thank you!!
