try a transmission flush, and find out if the torque converter is faulty or possible transmission solenoid is bad
gas mileage and RPM
Originally posted by mitsubishiv5 View Posttry a transmission flush, and find out if the torque converter is faulty or possible transmission solenoid is bad
Originally posted by emosun View Postok got em
at 60 / 2700
at 65 / 3000
at 70 / 3250
at 75 / 3400
at 80 / 3600
How could I set my timing to improve this gas mileage? I have done the ignition last year so it didn't change from the original timing when I got the car. I marked it. I did the valve lash adjustments and clean the EGR ports and valve as well. It drives smooth and shift good. I have change the trans.fluid 2 twice within 2000 miles and I used Honda's ATF.
Thanks.
Wow, you guys got really good mileage.
I have changed the rotor/cap/cables. All are NGK except for rotor. Timing is good. Oil change synthetic, trans fluid just done. No brake drags. Well maintained and no leak. Coolant is done as well. EGR cleaned. Air filter is good. Good tire pressure. Drive gently. Valve lash adjusted. Mixed local and freeway driving and I still get around 24mpg or less.
What else could I do guys to help with my gas mileage? I am unemployed, I cannot manage $40 per week fill up.
Thanks.
I'm sorry, but I wish you guys would post actual mileage calculations based on miles traveled diviided by gallons of fuel you actually put into the tank. There is so much variability in "per tank", it doesn't mean a whole lot. My wife usually only puts in 12-13 gallons at a fill. I'll usually push them to about 14, so our "per tank" mileage will be different.
I've put almost 4,000 miles on my EX in the last 5 weeks. All number below are purely highway:
34+ mpg at 65 mph max no A/C
31-32 mpg at 65 mph max with AC
30 mpg at 70 mph max with AC
28 mpg at 73-74 mph max with ACLast edited by Fleetw00d; 09-07-2011, 06:18 PM.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by fleetw00d View PostI'm sorry, but I wish you guys would post actually mileage calculations based on miles traveled diviided by gallons of fuel you actually put into the tank. There is so much variability is "per tank", it doesn't mean a whole lot. My wife usually only puts in 12-13 gallons at a fill. I'll usually push them to about 14, so our "per tank" mileage will be different.
Regardless, these cars are so old, and most are in various states of modification and repair... combined with different atmospheric conditions based on weather and altitude... one person's results will vary drastically from another's.
Your situation of oddly high RPM in the 60-70mpg range is one that is very similar to what I experienced when my speed sensor was out. Without the speed sensory working, my car would shift fine, but when on the highway I noticed the torque converter would not lockup, and my RPMs were probably identical to what you are experiencing now. So with that said, step one would be to identify if your TC is locking up. How to do it? Just count the gears as you get on the highway, and after you get into the 50-55mph area (maybe higher) you should notice another slight drop in RPM, almost like it's shifting into 5th. That final RPM drop is the TC "locking up" or spinning at a 1:1 ratio with the crank shaft. If you don’t see that last drop in RPMs, it’s not locking up. From my experience, if your TC does not lock up, it doesn’t mean you have a bad TC. You’re more likely to either have an issue of a faulty/sticky solenoid or faulty TCU not sending the signal to the lockup solenoid (or bad wiring in between).
The lockup solenoid is very easy to find, if you’re standing in front of the car and looking at the tranny you’ll see what looks like a pair of size C cell batteries sticking up, and there will be a wire connecting to the device. If you unplug the wire from the harness and measure the resistance between each of the leads going to the solenoid and ground (NOT resistance between pins 1 and 2), each one should measure between 14-16 ohms. If resistance is not in spec, replace it. If it’s okay, take a wire from the positive battery terminal and connect it to each of the solenoid leads, one at a time. You should hear a clicking sound. If not, you probably need to replace. If it works, you might want to remove the solenoid(s) and check the small filter screens underneath to see if they are clogged.
That’s where I’d start, and then get back to us. Replacing torque converter means dropping the transmission so it’s not easy. Good luck.
