Tach stopped working?
    Ok so my tachometer stopped working after I switched the guts of a donor distributor into the stock housing of mine. My guess is that the donor distributor came from an h23 maybe(found it in my buddies garage and plugs looked the same so I took it). After I found out my buddies dizzy doesn't fit I switched all the internals into my housing. Car turned on perfectly and runs perfect, but my tachometer doesn't want to work now? What I want to know is what wire on the plugs goes to the tachometer?
