White smoke is coming out of my exhaust only when I first start the car.
    White smoke is coming out of my exhaust only when I first start the car. There is none after that. The longer it sits the more it comes out. Any ideas what would cause it. Car has 212,000 miles original motor.
    does it hesitate a bit when you fire it up?
    a little bit of smoke is common in the wetter areas but vegas is pretty dry. id suspect a headgasket beginning to leak.
      It fires right up. I sometimes have to hold the key an extra second or two. It does however hesitate sometimes when taking off from a stoplight or sign.
        Do a comression test.
        1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
        Originally posted by keepinitclean
        I give it 2 weeks before you sell it.
          X2.
          Sucks man. White smoke is water/coolant burning in the cylinder. Hope its not your first go around with a headgasket, but I suspect the same.
          good luck man, start with a compression test!
          im a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
            Next time, have someone else start it. Stand behind the car, and see if the smoke smells sweet. If it smells sweet, it's coolant... which means your head gasket is on the way out.
            If it doesn't smell sweet, then it's possible that the smoke is just evidence of condensation in the exhaust system burning off.
