oil with spark plugs
    I pull my plug wires out and there is oil with them how to I fix this. I am bout to do a tune up and I don't wannna ruin new plugs and wires
    1992 lx sedan-christy-my black beast
    sounds like the valve cover seals that keep the plug tubes sealed off are worn and leaking. should be as simple as getting a new valve cover gasket/seal kit. fairly simple fix.
      i had the same prob. a while back . i just replaced the spark plug tube seals.
        http://www.cb7tuner.com/vbb/showthre...ght=tube+seals
        this should help.
          Yeah hopefully ^^ they're right, I had the same problem and I just replaced the valve gasket cover and all the seals, no more oil
          Its real cheap too, any autozone or kragen should carry it
            See that's the thing I changed that but still oil
              Did you change the upper and lower seals for the spark plug tube? The upper ones are easy to get to...the uppers are a little more work cause the rocker arms need to be pulled out to replace them.
              1993 Accord LX Coupe 5spd
                That's what it is I didn't do the lower. Ok ill buy another set and do it. And the tune up the same time thanks.h the link will be a great help thanks stretch
                  perfect video:
                  http://youtu.be/wYU8qtPzQOY
                  ninja edit: just saw that video link is posted in that thread as well. o well good info
                  -1993 Accord EX SOLD
                  -2012 GMC Canyon V8 4x4
                    i use to have oil in my spark plugs a couple years ago and never got to changing the valve seals, i checked not long ago and not really any oil anymore but there's now a white chaulky substance on some of the plugs?
                    IG:worldboss_sanjcb7
                      I changed all my stuff and nothing my ride is leak free now. But white chaulky stuff that couldn't be good
