Very Rough Rattle with a/c On.
    Ok so as soon as i took off my stock header i did some cleaning in the bay and wiped down the block with degreaser and some good old towels. the holes where the header was were blocked off so i know nothing was in there. i put in a megan header, downpipe, and hi flow cat which sounds much better with my ws2.
    So with all that done i rode around in my car for about 5 minutes and when coming to a stop with my a/c on my car rattles very hard. Things in my glove box shake and you can even hear my change in the tray. Now my question is could my header be the cause of this? it is a tight fit and the header rubbs a bit on the a/c pipe wrapped in the insulation stuff which i think might be rattling the whole block if thats possible. ive done some research on here so far and i think it could be misfiring like alot of other threads have suggested, but i wanted to get down to more specifics. pics or video can be provided if you need. i would rather not waste money on things that dont need to be replaced since i only have one job and bills. thanks alot in advance.
    that seems much too violent to be just a wrapped header contacting a small AC line (if it's the one i'm thinking of).
      Mine did the same thing and I cleaned the iac and mine stop shaking when I stopped also. I know sounds to easy but mine did it
      1992 lx sedan-christy-my black beast
        yea it sounds more like the engine is studdering and on the verge of cutting out.
          Mine did the same thing and I cleaned out the iac and the rough idle at stops quit. Sounds simple but it worked
            ill give it a try tonight. get back to you with the results
              Just wanted to say thanks alot guys. you have helped me alot with all my problems what not and yall are cool people. cleaning the iac and egr valve has fixed my problem!!!!
                Glade to hear ur problem is fixed
