i'm looking for a complete run down on the F22a1 and the H22a1. i'm looking for a like blue print or layout or something of these 2 engines. i wanna know everything about them. i wanna know measurements, horse power, torque, compression, everything. i wanna learn them inside and out. teardown and re-build type stuff. you know what i mean? that kind of info. any help?
looking for F22 and H22 info
Originally posted by 90_CB7_4door View Posti've look all over here to an i can't find the full info i'm looking for. or maybe i just havent found the right posting yet.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Originally posted by dj_ender View PostNo one is just gonna hand you all of the information you are asking for, your gonna have to do research, both here and on the rest of the internet. Then after you do that, after you put in some effort, then we will put forth the effort to help you with your questions. And he's right, this site is dedicated to those engines, pretty much all of the info you ask for its on here, its just not in one place, its pretty scattered. Until you put forth effort you will probably be ignored/ridiculed.
Originally posted by 90_CB7_4door View Posti've been looking around the web for a few days now an i just keep finding the same thing over an over again. maybe i'm not wording my questions right. but so far its mostly just been the same info over an over.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Originally posted by cbscandal View PostIs Google broken?
Originally posted by cb7_tillidie View PostDude WTF this whole site is practilly dedicated to these two engines. SMH!!!!!!
Originally posted by 90_CB7_4door View Posti'm looking for a complete run down on the F22a1 and the H22a1. i'm looking for a like blue print or layout or something of these 2 engines. i wanna know everything about them. i wanna know measurements, horse power, torque, compression, everything. i wanna learn them inside and out. teardown and re-build type stuff. you know what i mean? that kind of info. any help?
Most of the info you require is here:
http://www.cb7tuner.com/vbb/showthread.php?t=41915
http://www.cb7tuner.com/vbb/showthread.php?t=39834
What do you need the info for? Are you in the middle of a rebuild, planning one, deciding what pistons to use? etc . . .
If you give a better description of your plans and why you need the particular info you posted you will get much more useful information from the members of this site.
My 5.7 LS1 Holden Ute
Originally posted by Tippey764 View PostBanned members names are very dark now.
Unless you want to find out what Silver + banned = then reply to the thread properly or don't post at all.
Spend some time in the Technical and Performance Tech sections of this site, you can find piles of information on these engines. Also you may want to pickup a factory service manual for the car these engines come in (92-96 Prelude), you will find detailed specs there.
The information is out there, just be patient. I've spent years reading EVERYTHING on this forum, even if it was a modification or engine I had no plans to acquire, just for the knowledge of how it works, what to look for, etc; because I knew pretty much nothing about these cars. Now I'm comfortable with performing almost any common work on these cars.
Originally posted by evil_demon_01 View PostHow does that help the OP, and what does that have to do with the question he asked?
There is alot of information most people never really see about our engines. That will really help you understand and get yourself farmiliar with the way our engine is. For the most part the h22a1 is very similar to the engines shown there but it does have some differences.
Obviously it has vtec and the head design is different than the h23 dohc design
it also has a different automatic timing belt tensioner vs the manual ones found on the lower end engines ( its operation is shown in that video )
Skip to 2:33 in the video to learn all about the engines. There is other usefull relevent information ( since the rover 600 is a rebranded honda which is very similar to the CB chassis )
To answer evil demon this might help the OP by understanding that banned members names are written darker than silver members. It seems to be commonly confused which must be the reason banned members names were changed to be written in darker colors. it does not relate to the thread but i felt the need to point it out.
i didn't post blueprints but 8 years ago we all collected as much info on them as the internet had. granted there are still different versions of shit i have never heard about but for what you'll come across, you have the info on this site to make your own blueprint.
if you REALLY want a blueprint it would probably have to come from some promotional shit, i've personally never seen an f22/h22 blueprint....and on the 7th day, deevergote rested and called his mom.
Op;
Without knowing exactly what your looking for, to be quite honest its too much information for any one person to answer, completely in one post.
Tips on searching;
-Try using terms like "H22 or F22 piston size" "H22 or F22 wrist pin size" "H22 or F22 bearing clearances" "H22 or F22 cam lift/duration" "H22 or F22 stroke" etc..
Ask the search engine what it is your looking for specifically. And only pick one engine, I was trying to give an example. Anyways, if you look up the specs for whatever your looking for, you'll have better luck.
I guess what Im saying is your prolly going to have tough luck finding one page with everything on it. SO make a list, check it twice and search individually for the measurements you need, on the engine in question.
If your trying to hybrid stuff together, ask it that. Like "H22 head on F22 block" or whatever your looking for.
Good luck, and welcome to the siteOriginally posted by wed3kim a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
