Need help Odyssey rotor removal!
    Hey guys, I ran into a snag while prepping for my 5 lug swap. I have two front odyssey knuckles, both from the same car. The left side was the usual bang boom pow, and the rotor came off no problem. But the right side, no matter how hard I tried or finesse, it would not come off! PB Blast, WD-40, and Tri-flow have all been used. And yes the 2 screws holding the rotors in have been taken out. Any ideas? From what it looks like, the rotor has some kind of cap on it. Could this be my problem? I don't see it on the other rotor. If so, why would they be different? Appreciate any help. Thanks!
    No Problems with this one
    I don't quite know what that cap is
    That is not a cap
    That is a ring dug into the rotor from the anti rattle pad on the brake pad becoming dislodged
      There should be a threaded hole oposite where the screws are. Get a semi long 10 mm bolt and screw it in. Should push the rotor off.
        Thanks for the info Tippey. I found the hole, and it certainly was threaded at one point LOL, I'll dig around for a 10m bolt, but my gut instinct says those threads are gonna turn to dust. Thanks guys
          Looks like you need HEAT!
          1992 Accord Wagon (RETIRED)
