which distributor is best for the f22a1? internal or external ciol?
best coil?
They both work equally well. The external has more aftermarket options, but the stock components are good up to (or over) 500hp... so there's really no need to upgrade. The biggest flaw with the internal is the fact that the coil tends to fail sooner due to heat, as it's located much closer to the motor than the external. However, many of those internal coils have lasted 20 years, so that's hardly a big deal!
Originally posted by deevergote View PostThey both work equally well. The external has more aftermarket options, but the stock components are good up to (or over) 500hp... so there's really no need to upgrade. The biggest flaw with the internal is the fact that the coil tends to fail sooner due to heat, as it's located much closer to the motor than the external. However, many of those internal coils have lasted 20 years, so that's hardly a big deal!
