ok so when i got home today i pulled into my parking spot and pulled up to far. well when i put it in rev the car died and would not start after i put it back in park. then it started and when i put it back in drive/D4 it would rev just a lil before it moved. so i un connected the bat and now its fine. what could this be and how do i fix it? lmk asap call or text 817 751 0404 brandon
my D4 light auto trans was flashing?
Nobody is going to text you. If you're that impatient, have your car towed to a shop.
The flashing D4 light is telling you that the TCU is reporting an error code. Read the thread at the top of this section that says "read this first" (there's a reason for that...) and you will learn how to read and interpret the error code to determine what the problem is.
Usually, a transmission problem won't make your engine die, though. Is your Check Engine light on as well?
http://www.cb7tuner.com/vbb/showthread.php?t=53888
There is no way to really "check" it tho, u would have to get another one and replace it or repair the current one.
Under the dash, to the left of the steering column. You can get a picture of it on Google (brown and gray box with one plug coming out of it.) However, pull the code first to see if that's the issue. The main relay controls the fuel pump, so assuming that's the problem right off the bat could result in a wild goose chase.
However, the main relay COULD account for the engine cutting out... though normally it won't even start, since the fuel pump wouldn't be working.
Don't make assumptions just yet. Follow the clues that the car is giving you, and only when they turn out to be dead ends, look elsewhere.
Originally posted by The_New_Guy View Postsweet thanks =^) like i said i reset the car and now its fine. i will have to check it out more tonight after it cools off cause its 109 here
Originally posted by HardInThePaint View Posthttp://www.cb7tuner.com/vbb/showthread.php?t=53888
Or you could just open it up and see cracked solder joints
