Loss of power
    Loss of power
    Hey again everyone, I have a new problem for you! The car is an automatic '91 ex-r.
    In different gears at different speeds, my engine will missfire. I'm trying to accelerate when the speed plateaus and starts to sputter and struggle. I lift off the throttle then accelerate a bit faster and sometimes this temporarily fixes the issue, or just downshifting as if I'm overtaking will do it. In traffic I'd be forced to push the throttle and come off it when I know it's going to miss and just repeat the pattern until I can either speed up or come to a stop.
    This issue is recurring, but not frequent. I wonder if it's the oxygen sensor, spark plugs or plugged up fuel injectors.
    Any ideas?
    Your description sounds very much like an oxygen sensor problem to me. I would replace that (Denso or NGK/NTK only... no Bosch), and see if it fixes the problem. If it's not the cause, at least you've replaced a wear item that will most likely need to be replaced soon anyway.
    In the meantime, you could pull your spark plugs and inspect the tips. If they are bad, you'll be able to see it.
      Even if it is the oxygen sensor, I ahve a new one I never used that was supposed to go into the last cb7
      Thanks for the advice, now for the time to check it...
        Just make sure the sensor is for the right model. The EX-R will have a different location and plug than the EX and DX. (and if you happen to have a USDM model, it'd be the EX that has the different plug, with LX and DX being the lower models.)
        Also make sure the new sensor isn't a Bosch. If it is, don't waste your time installing it. It won't work properly. They NEVER do.
