Originally posted by dj_ender
View Post
No sign of vacuum leak Idle problem
Originally posted by wed3k View Postso the fitv is bad. ive changed one before to stop a high idleOriginally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Your guess is as good as mine. I too don't know how it went bad or is bad.
The fitv has already been cleaned twice and no change. Also the plastic screw inside the fitv is closed tight and that did not do anything. At this point in time I have done everything.I could with still having the problem.
Originally posted by dj_ender View PostOk maybe I'm stupid, but how the fuck does an fitv "go bad"? Its a spring, a copper nugget, a retainer, and a plastic nut, clean that bitch, reassemble it, and tighten the nut down. Its not a sensor, there's nothing to fry. I mean the spring COULD break, or the retainer, pull it apart before you go buy another one and clean it.
Originally posted by DejectedAngel View PostYour guess is as good as mine. I too don't know how it went bad or is bad.
The fitv has already been cleaned twice and no change. Also the plastic screw inside the fitv is closed tight and that did not do anything. At this point in time I have done everything.I could with still having the problem.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
I'm having the exact same problem. The erratic idle only exist after the T-stat opens. I believe it's a vacuum leak. I state this because once in a while, I'll be sitting in traffic, and I'll feel a drastic drop in brake pedal pressure
BTW, did you figure out the culprit/solution?The Lord watches over me!
"Stop punching down on my people!!!"
- D. Chappelle
Hello, here is Honda's procedure for diagnosing a fluctuating idle. Sorry for the poor scan quality on the italic text. All steps with italics ask if the car stalls except for step five, which asks if the car still runs. This check list was able to help me identify my high and fluctuating idle. It happened to be a leaking intake manifold gasket. BTW, did you spray carb cleaner on the under side of you IM gasket from under the car? Could be a leak down there. Thats where mine was. Good luck and I hope this helps.
If no vacuum leaks are present and your IACV is good you might want to make sure your engine temperature sensor is working properly because if your motor is at operating temperature and your sensor is reading colder than actual temperature the ECU will advance the timing to raise the idle in order to pull in more air in an effort to raise engine temperature and therefore your idle will never come down try putting on a new temp sensor and see if that solves your problem
