While fiddling with the car, and finding out how difficult it is to remove the runners, I think I found the source of my vacuum leak. Upon taking apart my map sensor/black vacuum box, I notice that some of the hoses has small incisions/cuts/openings in them at the ends. I hope this is the culprit as I'm replacing the hoses and putting everything back together.
No sign of vacuum leak Idle problem
More inspection led me to realize that the black vacuum box under the intake that controls the secondaries was cracked in two places> I'm sure this was a place that was leaking air. To solve the problem as simple as I could, I deleted the box. I know the my secondaries will stay open, but who cares? This motor wont be in the car for very long.
Summary, when looking for vacuum leaks\:
- inspect all lines from the map sensor/black vacuum box for vacuum hose deterioration.
- if permissible, inspect the little black box and hoses under the intake if you have a F22a6.
I believe these were my vacuum problems. Time will tell. I'll update tomorrow when everything is back together.The Lord watches over me!
- D. Chappelle
