swap HELP!!
    swap HELP!!
    so i have a 93 accord ex auto n im making it stick with a engine swap 2 da engine came out of a 94 ex vtec i basically took apart da 94 n im swaping it to da 93 but the trans mount does not fit do i need a manual trans mount? anybody can help me out??
    also is it going to be too hard to wire the harness?
    I can't understand a goddamn thing you're saying... type in English, and post a picture that doesn't require me to scroll over another full screen...
    Also, the F22B1 sucks. It's a terrible engine for performance.
      Just because it has VTEC doesn't make it good. You really have no reason to swap the engine unless the stock one was blown out or you're actually upgrading in some way.
      Yes you need a manual transmission mount. You can get them off the donor car, remove the stock auto mounts, and then weld in the new ones.
        all i want is just a stick shift here in chi town deres a few cb7 that are manual and im probably the only one with a nice accord here later in the future im planing on getting a better engine but tanx
          You don't need an engine swap to make it a 5 speed. It probably would've been easier without that, actually. And cheaper.
          Congratulations on the whole nice Accord thing. Hope it works out for ya.
            tranny swaps are very easy compared to full engine swaps and manual trans wiring should be as simple as either getting a chipped ecu or a manual from your same car
              The "sticky" threads in the Swaps section of this forum show you in detail how to do both the 5 speed conversion and the shitty F22B1 swap.
                What harness are you talking about?
