autolocks not working.
    Autolocks not working at all, wondering if anybody has any suggestions where I should start to look into. When i flick the button it doesn't do anything at all regardless if the car is on or not.
    If you have any suggestions thanks !
    If there is no sound or clicking, then check your fuses under the hood and then check the window switch itself. If it was the power door lock actuator, you would at least here a humming when they don't work. Have you pulled the door apart to make sure all plugs are connected to the harnesses? You can also check for frayed or missing wires.
      thanks the fuse was cracked +
        you seriously posted a thread without even checking the fuse box first? epitomy of lazy much?
        Parts For Sale
        BIG Thanks to HondaFan81 for all your help!!
