Pop sound while putting it in to reverse.
    my accord wagon makes a pop sound which is not that loud but i can hear it when i put it in reverse. its a automatic trans. idk if this is normal or not. i
    It could be a lot of things. CV shafts, loose suspension parts, loose steering parts, loose brake caliper or pads, etc. Your best bet is to have a buddy help you locate where the noise is coming from.
    My MRT: http://www.cb7tuner.com/vbb/showthread.php?t=200048
    (Turbo lag - turbo power) + HYPE = VTEC
    Bought From: Davids92Accord
    Sold To:
      have someone in the engine bay, look at the front motor mount while you put it in reverse.
      Retro!
      Hater
        if you hear metal/metal clink, then its most likely motor mounts, check the rear and the front one for excessive movement
