egr port cleaning
    egr port cleaning
    I've read the DIY but it doesn't say what to use. it only says carb cleaner and compressed air. I don't have access to compressed air nore do I have the money to buy a can. is there something else I could use to clean them out?? that's fairly cheap that'll get the job done?
    I'm having the sputter affect near 2k rpm I'm hoping this and a new egr does the trick. if any other suggestions lmk. it's driving me crazy
    http://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
    diy whore riiittteeee here
    [URL="http://www.cb7tuner.com/vbb/showthread.php?p=2208455"]
    http://www.b20vtec.com/forums/members/pr3pg4lyfe.html
    Just use the short end of an allen wrench and get up under and inside the ports real good and scrape all the carbon loose you can and use a vacuum cleaner with a tube attached/taped to it to get down in there and vacuum all of it out you can.
      I used like 7 cans of carb cleaner withe the intake mani off. also taped pipe plugs in. wasn't that hard.
        I sprayed some SeaFoam aerosol in mine to get a good clean.
