what could be causing this and is it bad? what problems will or could this cause to a car and how can it be fixed?
f22a1 vacume hose question
Thats the pcv if its kinked bad enough to cut off breathing it will cause unwanted pressure in the engine/crank case an ya don't want that.The pcv is a vent for the engine to release pressure.Just replace the hose shouldn't be over $3.
02 Crv
Possibly yes its vaccum pulled from the intake.Replace the hose(any local parts store should have the size of vaccum hose you need) an go from there.
02 Crv
They usually are an OP might aswell replace the pcv while hes at it.They are also cheap.
02 Crv
What I was getting at was that most likely his IM is caked with oil and other nasty gunk, THAT would totally cause his issues. Op, pull off your intake tube, turn the tb to WOT and shine a light in there and let us know. I bet its nasty in there.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Originally posted by dj_ender View PostWhat I was getting at was that most likely his IM is caked with oil and other nasty gunk, THAT would totally cause his issues. Op, pull off your intake tube, turn the tb to WOT and shine a light in there and let us know. I bet its nasty in there.
02 Crv
Right, just making sure the op knows to check and clean the IM. I got bored one day and just ripped off my IM to clean, for no reason and it was nasty, 2 cans of brake cleaner later and it was spotless!Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
I've seen some really bad ones that looked like they could cut power down quite a bit.Cleaning of all ports every now an then isn't a bad idea.
02 Crv
As far as I know the only real way to do damage is to leave It soaking too long. I've used it many times in multiple cars, and no issues. Of you plan to use it go to youtube, search seafoam and watch the one by seafoam. Used right it can really help your engine, especially a 20 year old car like ours.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
