I just recieved news of a dude swaping a k20 manifold on a h23 motor.It gave the motor a better air flow and a gain on high rpms.now my question is if its a good idea to swap it on a f22b1head to give a better flow..will it a help me and give it better easy pick up flow of air.and is it possible to do that swap on a fseries.?
k20 intake manifold on h/f series
it has been done, this intake manifold gives more power than the skunk2 actually
the only downfall is, to use it you need a spacer/adapter which is worth aorund $250 and the manifold itself goes for $300, on top of that, you can either stay with the k series TB, or they sell a spacer for that too
way more money than S2 or euro R, few HP more
it will fit the f22a actually, using the k spacer on a h spacer then on the f22, so technically it fits but at this point a custom manifold will look better and cheaper
S-swap, where in his post does he mention f22a?
intake manifold from a clock-wise spinning engine can be used for a counter-clock wise spinning engine
To add the f22b1 has a different bolt pattern than the F22a an the H23 so regardless if it fits an h23 or F22a.It have to be modified even more to fit the F22b or F23.Now you can use the F23 mani as an upgrade on your f22b1 there is write ups about it out there if your interested.
02 Crv
As long as the ports aren't to far off, I doubt they are, you could always have someone chop off the flanges and weld it back up.
I just may look into that if I can find a stock manifold cheap enough.1991 Accord Ex - H22A - Omnipower Coilovers - Greddy SP2
1993 Civic Dx - D15B7 - T3/T04E - Ported head - Hole in block - May be going F swap
My Workout Log
Originally posted by LeungWell, I poked the big one in the head with the shovel while shouting at it "hey, you can't sleep here".
Originally posted by kronikally420 View Post"K's spin the other way
K has the intake in the front"
doesnt that mean that they spin the same way? in a sense..
they both turn toward the exhaust
idk, im a newb
Originally posted by The Producer View PostEngines will always spin towards the front of the car....
1990 CB7 - Almost Done - Delta 272, SRI, 2.25 catback, Bisi intake manifold gasket, A6 intake double stacked, H22 plenum, AEM cam gear, F23a block, F22a head, Wiseco K20 pistons, DSM 450cc injectors
2004 Z33 - Brembo BBK, Nismo spoiler, Nismo lip, Nismo shift knob, AEM CAI
