Throttle body upgrade
    I'm interested in increasing the my current TB to a 70mm model. I was wondering if this is a reasonable upgrade and if anyone here has done this with any feedback on the pro/cons of this upgrade.
    Thanks
    It's a good upgrade... just remember that the engine can only flow as much air as its biggest bottleneck... so if you can take in a lot of air, but you can't flow it at the same level all the way through the engine and exhaust system, then the benefits will diminish.
      cost like what...75 or 90 bucks? I mean with shipping and all...both ways
      ____
        This is doable
          I did a bigger throttle body on my last civic. After doing it the only issue i had was it idled really low and died sometimes when cold, but once heated up ran like a champ. car was fine till i changed it. I tried adjusting everything but it had the same results. Not sure if this is common from switching them out to bigger ones but i tend to stay stock now.
