Fuel Gauge fluctuating?
    I don't know if this is standard on the car or if its something wrong.
    My fuel gauge only rises to the appropriate reading when I accelerate and goes down to Empty when I brake. Why?
    It is normal for our fuel gauge to fluctuate to a moderate extent. This happens because of the way the fuel tank is designed. The mechanism that determines how much gas we have is a float, which is located on the rear of the gas tank. When braking, gas will slosh to the front of the tank, while accelerating will push the gas back to the tank. The reason we "Gain" gas while accelerating is because more gas is being pushed towards the float. However, it is a mere 1/8th of a tank that my gauge fluctuates, if yours does significantly more you may have a problem with your float (the correct technical term escapes me for the the moment, sorry)
