exhaust hole
    Does it have threads? The reason why I ask is because you have an oxygen sensor near there. If that's not the whole, you need some fab work done. That or a new exhaust/component.
    The Lord watches over me!
    - D. Chappelle
      Originally posted by phantomcow2 View Post
      Are you running the stock setup? Ebay headers, which include everything that's leaking on your car, are a dime a dozen. I wonder if JB weld would patch it up.
      Stock setup yes. I was kinda of hoping the entire exhaust would disintegrate at once, so then I could justify stainless steel all the way back.
      If the problem gets too bad, I'll likely go with an ebay header.
      I don't think JB weld will fix it. It's formed like a slit across the top.
      Does what have threads? The upper header part does (the actual header) and everything is threaded together. I have the F22a1, so my O2 is on the correct spot.
        The reason I went for an eBay header was because my flex pipe was rotted out and, as counter intuitive as it seems, it was cheaper to get an eBay unit for about $70 shipped than weld in a new flex piece! The eBay units get a lot of flak, but I've had mine in there for 4 years and it has been great. All of the original gaskets are intact. The flex piece did fail after 3 years, which isn't unreasonable IMO.
          I'm not sure what you're talking about
          I put the utmost care into every post I make.
          Your original post was quite bad, and that is me being exceptionally nice. Its amazingly poor grammar that was the entirety of your orig post that a few have referred to and honestly I'm shocked you have gotten the amount of help\replies that you have as typically you will all but get ran off for a post written that badly.
          To answer your question, no it wont hurt anything to have the small leak. If it is a large leak and very close to the O2 sensor then it can cause some engine problems- rough acceleration, loss of power, CEL coming on. If its not bothering you sound wise, ignore it until you want to spend the $70 for an ebay header. OR....hot up a junk yard and grab a used exhaust manifold with the down pipe and call it a day. If you can weld then you can install the header yourself and the problem is solved.
          Bought from Darkcloud
          http://wheelflip.com/r/DrAkE
            English please.
              My original post was superb. They always are.
              Currently, I'm most worried about the gasses poisoning me or melting something. Other than that, I'm fine with it.
                Originally posted by Maple50175 View Post
                English please.
                Was?
                  MmmmmmK, lol
                  As for gasses or heat....an expert I am NOT but ive had an exhaust leak under my engine for weeks, I drive 3 hours a day to\from work windows up with A/C or down and enjoying the wind and there is no gas fume at all. Heat coming out of a tiny leak will be so minimal as to be a non-issue in the already hot engine bay plus your moving most of the time anyway, the draft under the car as you move does more to cool things off then that crack of heat will ever do to make things any warmer.
                    Another dumbass post:
                    http://www.cb7tuner.com/vbb/showthread.php?t=180940
                      WOW, its so bad its funny....almost
