So i recently swapped my maroon dash for a black one. i used the old harness and everything hooked right up. However, lately my car will not start. I have jumped it 3 times, and it fires right up. So i bought a new battery since mine is probably 5 years old and has a lot of corrosion. Still problems starting Today i started it and the s light started blinking and 1st and 4th gear were unresponsive. Any idea of why my car wont start sometimes? i will gladly give all the information i can. im just trying not to go to the honda dealership
Car starts randomly. Dash swap. S light Blinking
what happens is it cranks/clicks, but the engine never fires up. 10 minutes later it will start just fine. I think it may be an electrical issue since this started happening immediately after i swapped the dashboards.
i dont know if the fuel pump is coming on or not, my guess would be that it is since it starts right up 10 minutes later
The main relay is what he is getting at. It's a common thing to fail, and will result in a random no-start before it fails completely. Other common potential problems would be the igniter and ignition coil, as well as corroded or loose battery or ground connections. What you need to do is determine whether or not your engine is lacking spark or fuel. That will narrow things down considerably. If all you do is guess at your symptoms, we can only give you guesses for solutions.
The blinking S light is an indication of a transmission computer error code. The "read this first" thread at the top of this section will tell you how to obtain and interpret that code.
so i have a brand new battery in with no corrosion. battery light has never come on. when i replaced the dash were there any wires i needed to ground? No more s light problem, i just unplugged the green clip above the fuse box and plugged it back in and that fixed the problem.. is a main relay easy to replace? sorry i have very limited knowledge about cars but i am learning!
What green clip did you unplug? the S light was telling you something was wrong... it wasn't a problem in itself. If just unplugging and reconnecting that plug made the light go off, you didn't fix whatever problem it was telling you about. It will very likely return.
The main relay is easy enough to replace. It has been covered MANY times before on here... it would do you good to do a bit of searching, as you clearly haven't even tried to find the answer to your questions (had you read the "read this first" thread at the top of the section, you'd be halfway there.
The battery light wouldn't need to come on for a no-start. Ensure your connections are good. Just because the battery is new doesn't mean your cables aren't all covered in shit.
Determine if the problem is due to a lack of spark or fuel. Until you do that, we're wasting both our time and yours just throwing out guesses.
alright im pretty sure the fuel pump isnt kicking on, because i dont hear it. this all makes perfect since now!!!! sometimes i can tell that theres fuel in the lines because the engine ALMOST fires up for the first few times bet then only cranks after that. so im going the replace the main relay and hopefully that will fix the problem. Again, are there any wires in the dashboard that could have caused the main relay not to work, like an improperly grounded wire?
