What is everyones take on Fuel Filters?
    I am doing a main relay swap this week and was contemplating swapping out my fuel filter as well. I haven't touched the fuel filter in the 6+ years I've had my cb7 and who knows when or even if it has been replaced at all during her 21 year life.
    What is everyones experience with cb7 fuel filters? Do they clog within a few years? How often do you guys swap out yours? Is it an easy job? Is it worth doing if you are having fuel pump and or fuel injection issues before an actual fuel pump overhaul?
    Well i can tell you its very important to swap out. My car died on me last week for what seemed like no apparent reason. I checked everything in the car and did not find anything out of place but i decided to swap it out before buying a new fuel pump and my car started right up.
    Originally posted by Uncle Willey
    When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
      I've replaced mine twice, just out of pure whim, thinking it should be done at least one in ten years. They do clog up, but I've never had any problem with them. The one thing you do need to be aware of is that gas does leak when swaping them out so put some cardboard or something under your car.
      Current
      1992 Accord EX 5-speed Sedan
      Rosewood Brown
      1992 Accord EX 5-Speed Sedan
      Arcadia Green
      Previous
      Bordeaux
      1993 Accord LX 5-Speed Sedan
      Bordeaux
        Fuel filters don't generally just fail. It's usually a combination of water or contaminants in your gas tank. Since our cars are so old (yes, hurts me to say), the fuel tanks can get somewhat brittle inside along with the fuel lines. Eventually, these contaminants reak havok on our fuel pumps and fuel filters. But, because they are so easy and cheap to replace, why not just throw a new one in.
        that's my two sense...
          had a slight stall during take off and replaced mine...vrooom it went.
          wish all parts were this cheap.....now it time to replace the distributor
            I change mine when I change my spark plugs. I just consider it a part of a full tune up.
              does anyone have a brand they prefer?
                I just got what ever autohouse.com had for sale
                http://www.cardomain.com/ride/2620526 190E Mercedes Benz
                http://www.cardomain.com/ride/3065882 Accord Under major Repairs
                  It's definitely worth replacing. I had a problem where the car would completely lose power, and often bucked while hesitating. Swapped the filter out and I've been problem free for the past 4 years .
                  I don't recall the part being expensive or difficult to replace, so IMO it should be replaced as preventative maintenance. I think I'll do it again within the next couple of weeks.
