ok ive had this problem for too long and its annoying me, on my passenger side front window,the little black pieces the hold the window to regulator will not stay on the window, so when i roll the window or try to roll the window down the black clips always slide off! ive tried pretty much every thing,glue super glue, gorilla glue,so crazy super adhesive junk that i had to mix two compounds,nothing works,so the window just stays up any ideas?
with any glues/adhesives its important to thoroughly clean area to be glued.
if you did that and still no dice... i personally would go to my local junkyard and pay the minimal amount for a replacement. if you decide to try again may you can CAREFULLY wedge another piece of material inbetween the glass and the plastic part that rides on the elevator arm.
