Lining up points on the distributor to match another car is not the same as setting your timing properly. Set your timing with a timing light.
If you halfass everything, there's no way we can help you. It's much easier to diagnose a problem when there aren't a handful of other things wrong that may or may not be contributing to it. If your ignition timing is way off, it will most certainly affect the way your engine runs.
