Bad leak. No idea where leak is...
    hey when you installed that new crank shaft seal, did you also install the retainer clip?
    it's to keep the seal from "walking" out again and only cost a few bucks at the dealership.
      Originally posted by YK86 View Post
      An oil leak that happens all of a sudden and leaks that much is usually the balanceshaft seal. Could be the cam seal but not as likely to leak at that rate.
      DON'T run the car anymore. You are actually lucky you made it home as a lot of people who keep driving when the oil light goes on with the balanceshaft seal popped out kill their motor.
      yes. popped a major seal, draining all oil and therefore causing the oil pressure light to come on.
      It's not a fluid light, it's an oil pressure light.
      Good luck you got it back without seizing the engine.
