I've turned the rotor over and over and over and I still don't see a screw. There is a black plastic cover below it. Do I have to pull/pry the rotor off? Sorry, I am a first timer putting one on
Rotor button removal HELP PLEASE!!
Originally posted by deevergote View PostIf it's an OEM rotor, there will be a screw. If it's an aftermarket replacement, it's probably just a slip-on type, with a clip inside. In that case, it just pulls off. If it's been on there for a long time, it will probably be difficult to remove. Just be sure to pull it straight off.
Simply pull it off. Its gonna be stuck on there pretty good if it hasnt been changed in a while. When you put the new one on, make sure you clean the surface of the distributor shaft with some fine grit sandpaper, and use some dielectric grease when you put it back on, very little, not much at all, just to give it some better contact with the shaft, and to keep the humidity off it.90 Accord EX F22a1 Auto R.I.P.
2011 Mazda 3 Hatch 2.5L GS sport HELLO!
Sorry, I didn't see the picture when I just posted that last comment. But on the clip on type, where you would slide it on, it looks like you can see the metal contacts. Almost like they slid out a little from being worn
Would it be ok to use a penetrating solvent or would that damage the electronics on the inside?
Yeah, sorry, I used the edit button to add the pictures (you should use that as well... don't post repeatedly one after another...)
If you use any sort of penetrating solvent, just be careful not to get it inside the distributor. You really shouldn't need any, as it should just slide off if there's no screw in that flat part. Just pull it straight off... give it a good tug, or pry it from two sides (so the pressure is going straight, not sideways).
Originally posted by deevergote View PostYeah, sorry, I used the edit button to add the pictures (you should use that as well... don't post repeatedly one after another...)
by the way, after prying at it for a good bit....I finally got it off
THANKS EVERYBODY WHO HELPED OUT!!!!
