I know i might confuse some ppl and might not interrest them, but still something i've noticed that change without any hard labor.
I know ppl would say just get the cluster out and remove the light where the ABS is but thats not the point. I wanna know if anyone else have noticed any change or found the same tricky way to keep it "off".
So i finished working at 1:30am... yeah i did late night work. I had to give a ride home to a partner. <-- not really important but still in the story. I do have the DRL and i've set the yellow bulb in it so i can have a good clean look when i paint my high beam yellow, Also got the fogs with yellow HID.
I started the car, put the fogs on... DRL went on when the e-brake been removed... but since it was at night i decided to run only with parking light so ppl can still see me going. After 15 to 30sec from rolling you should get normaly the ABS light up in the dash... this time the ABS stayed off... I... WTF!?!?!? confused as i was expecting it to light up... and realised what i've done. Later on, at my partner's place i went in grab a beer and talk... had to leave so i wanted to make sure that wasn't my mind playin me. So i did it again, put the parking light on and run with the DRL for about a minute. After all i putted the headlight on to be secure(passing by a police station :P )... and seen that the ABS was still off and wasnt plaining on lighting on.
So i'm wondering if any other seen this before, or know why it does that?
I'll get a vid of it later on.
