I know the XTR clutches have a bad rep of being garbage but is the 10lb flywheel any good? I found one i can pick up for $30 off a friend of a friend so i am trying to do some research before i buy and trying to get an opinion from anyone who has used them.Thanks in advance.
XTR 10lb flywheel any good?
Originally posted by 92smokeaccord View Posti dont think xtr made a flywheel its probly a fadanza...iv had mine for 3-4 years and still kickin...
XTR and XTD are the same thing, from what I've read. XTD got a bit of a bad rep, so they renamed it XTR and people started buying again.
I have had an XTD 10lb flywheel in my car. It worked well... no issues directly associated with the flywheel. However, EVERYTHING got destroyed in about 60,000 miles when my throwout bearing seized... so I can't give an accurate long term review. Honestly, I would get something better, just to be on the safe side... and ALWAYS use a throwout bearing directly from Honda. They aren't cheap, but it's a lot cheaper than having some garbage aftermarket bearing seize on you, trust me!
Thanks guys...for $30 bucks i think it might be worth a try and an afternoon of my time to install. I will check the balance on it before installing. I will be eventually buying a new stage 2 clutch kit sometime before the years end so if it doesn't go well with this flywheel,then i'll just throw in a fidanza in there along with the new kit.Thanks for reading and your input guys.
"stage 2" clutch kit means nothing... Get a quality clutch kit that meets your needs. A "better" clutch isn't a performance upgrade. If you're only putting down 130whp, which is what a mildly modified F22A would be doing, than a quality OE replacement clutch, such as Exedy, will do everything you need. A cheapie "stage 2" will probably fail sooner, and chew up your flywheel... and a quality "stage 2" will be far more than you need (and it will also chew up your flywheel.)
Have you changed a clutch/flywheel before? I assume so... but if it's your first time, be aware that it's a pain in the nuts. That's why I always stress quality parts, because it's an annoying bit of work to redo because you cheaped out on parts the first time around!
Originally posted by deevergote View Post"stage 2" clutch kit means nothing... Get a quality clutch kit that meets your needs. A "better" clutch isn't a performance upgrade. If you're only putting down 130whp, which is what a mildly modified F22A would be doing, than a quality OE replacement clutch, such as Exedy, will do everything you need. A cheapie "stage 2" will probably fail sooner, and chew up your flywheel... and a quality "stage 2" will be far more than you need (and it will also chew up your flywheel.)
You've got pretty much EXACTLY what I have...
I would honestly go for an Exedy clutch. My friend picked up a "Stage 1.5" a few years back. Not sure if it still exists, but the Stage 1 is probably fine. Even an OEM replacement for that much power would hold for quite a while.
As long as you're staying NA, and not racing it all the time, you won't burn through even an OEM replacement clutch very quickly. If you get a stronger clutch, it will eat away at your flywheel (just as performance brake pads will destroy your rotors quickly... that's another thing I always suggest people get ONLY what they need, and no more...) For a mild N/A build, you don't need all that much. Forced induction is where it helps to have a stronger clutch, because the increase in torque is substantial in that case.
I'd stay away from XTD and F1... based on my own experiences with XTD (even though my car has an XTD Stage 1 in it now... that was due to convenience, though.) Exedy has what you need, at a similar price, with MUCH better quality.
I am just looking for a decent to good clutch that will grab good enough to feel the difference between gears and not that sluggish feel with a stock clutch. But also have a good enough quality that will last at a reasonable price. LOL...that's all! Like you said,something that would work with my goals and not overkill.
The sluggish feel isn't really the clutch, unless it's slipping... of course, those cheapie clutch kits come with squishy pressure plates. My XTD Stage 3 (back before I knew better than to get a "better" clutch than I needed) felt worse than my stock clutch because of that crap pressure plate.
What transmission are you using? Is it an Accord or Prelude transmission? If you're still using an Accord trans, the gears are longer than the H22 likes, which definitely gives a sluggish feel.
I am currently using the Accord tranny which i know sucks with the H22 but i do have an m2a4 that i will be dropping in as soon as i get the case fixed. That is why i was asking about the flywheel so that i can pop it in there at the same time.I should be putting it in this month but since things are tight i won't be able to afford the clutch kit now. Which is fine 'cause as i mentioned earlier,i don't mind doing the work. Sure it sucks doing it twice but i don't want to wait 'till i can afford the clutch kit to drop my Prelude tranny in
