Starting problem
    Starting problem
    Hello! I've been a browser for quite sometime and problems occurred so I'll be posting this thread!
    Alright, I've had my 1992 Accord LX for about 2 years. It ended up sitting around since last August. The battery ended up dying out on me. I got a new battery, hooked it up backwards like an idiot I then realized since I couldn't get the one terminal on. I turned it around, hooked it up again and... nothing.
    I had no intentions in messing around with it until today. I thought the guy might have given me a wrong size battery since there was some room left in the tray. Turns out, he did. So I get this other battery and it fits in snug. I make sure I didn't put the battery in wrong again. Now, nothing... still.
    I look around and noticed by the fuse box, a wire is all nasty and crispy looking. It's like white creamy stuff (nothing from my reproductive system!)
    I am car retarded and would like to know what this is called and if it can be replaced without an arm and a leg.
    Crappy cell phone pics, but you get the idea!
    Thanks guys! I want my CB7 up and running again!
    That is dielectric grease. Nothing out of the ordinary there.
    Regarding your starting issues, have you checked all of your fuses? Main relay? Cleaned all of your battery/starter/alternator terminals?
    29 MPG in town ~ ?? MPG Highway
    "how can I make my car unique, just like yours?"
      That is normal. Nothing to worry about
        Alright, so that wire is fine then? Haha, well I'll check all of the fuses and what not, how do I know if they're bad or broken? I'm not joking when I say I'm car retarded!
        Thanks a lot so far though.
          check your 80 amp battery fuse. You probably blew it. It that big square looking fuse that you can pretty much see the filament when installed.
            When you install the battery backwards you're usually going to blow something, in most cases, just a fuse.
