h22 swap need info
    h22 swap need info
    hi,
    i am done swapping an h22 into my 92 accord, all that is left to do is replace the power steering line (wich broke when i welded it) and figure out wich mount will attach the tranny (m2a4) onto my cb7 frame???
    i have been told to buy a 94-97 accord manual transmission mount, wich i did...still doesnt fit...do i need the big metal bracket that goes in between the mount and the tranny from the 5th gen accord too?? (3 bolts star shaped bracket)
    also i read a thread on this forum that was showing how to tap new holes into the transmission and move existing studs into these holes...is this the right way of doing it? and if so, wich mount will i need then?
    i know this has been debated 1000 times and i did some research before posting but i am still unsure of the way to go.
    thanks
    MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201008
    If you drill and tap the tranny you retain your stock transmission mount.
    92 CB7 F22 5 speed.
    ^MY RIDE THREAD^
      You need only the (94-97) transmission... but you HAVE TO reuse the orginal mounts from you 90-93 CB.
      Checkout my MR: http://www.cb7tuner.com/vbb/showthread.php?t=165984
        alright, thanks i will tap those new holes
        and no, i wont run my h22 with a 94-97 transmission
          Why not? It would work.
            because i already have a working m2a4...why would i wanna go buy an accord tranny
            plus the gearing is longer on the accord tranny for all i know...
              Who said anything about an Accord tranny.
              Honestly, the only reason the transmission was brought up was because your first post was a bit difficult to understand, and the person that mentioned the transmission didn't read it correctly.
