I have a 93 Accord EX 5 speed. She was starting fine until one day i went to start her and nothing. I get power to everything, she just won't turn over. I can push start it and it runs fine. My battery reads 12.75v, i cleaned all the posts and terminals, changed my main relay, jumped the clutch switch with a paperclip, distributor is fine, alternator is fine, all my fuses and relays under the dash and under the hood are fine, the starter is fine, had it checked, and its getting 12.75v from the battery. At this point my only concern is the small spade/blade connector that goes to the starter.. its only getting 0.02 volts when i turn the key. If im not mistaken that lead is supposed to get 12v to turn the starter? So before i go ahead and change the Ignition Switch, what do you think?
problem starting
have you hit the starter gently and tried to turn it on?AT WEST COAST MEET
cb7rush: who has the tongs?JDMxDB8: i got a thong on...
to get to see more of my cb click the link below.
http://www.cb7tuner.com/vbb/showthread.php?t=130922
the starter is fine, she turned the car on when i applied 12v to the blade connector. i pulled the starter cut relay out and the coils inside were all messed up. so i jumped the connector with a wire and she started right up. i figured out you can completely bypass the clutch ignition switch by jumping the starter cut relay plug with a wire.
now heres another question. will having the starter cut relay jumped with a wire end up messing something else up?
