Cut Bump Stopper?
    Cut Bump Stopper?
    Cutting bump stoppers in half safe? I was told by a prelude driver that he has half a bump stopper on all 4s with a 2" drop on some skunks. " better center of gravity." is what he said...
    RIP 4/23/12...lets not forget, the 88" Z31 turbo, are my dailys
    Dude !
      It shows I pissed off "the man."
        Well dont piss off the man. He is Cool. He pays out of pocket to run this site for people like us.
          Cutting bump stops has nothing to do with the center of gravity.
          Also, "The Man" has nothing to do with the rep you have. He can do better than hide behind a computer and leave anonymous rep points.
          1996 Honda Civic LX 2009-2012
          2012 Kia Optima LX 2012-2013
            Reincarnated Turbo Dave v2?
              cutting the bump stops only allow you have more downward suspension travel. the bump stops are there for a reason. if you cut them or take them out, it will allow your struts to be more vulnerable to bottom out and it will blow them. leave the bump stops in there and do not cut them.
              MRT: http://www.cb7tuner.com/vbb/showthread.php?t=183959
                Leaving the bumpstops uncut on a lowered car will make the setup bouncy since there isn't enough shock travel. This is why good quality struts are needed on a lowered car. It is needed to compensate the lower shock travel.
