diagnose this sound please
    Now that i have an exhaust manifold installed correctly i don't have any major leaks so i can listen to the engine run
    I get this bad noise as you can hear in the video and am not sure where its coming from. Anyone have any tips? I think im going to go do a valve adjustment next but what do you think.
    That Sir sounds like a spun Bering.
    Take a look at my MRT!! Thanks
    http://www.cb7tuner.com/vbb/showthread.php?t=186609
      try putting the plug in that goes next to the engine identification. then see if you still hear the noise.
      "My FOR SALE thread - Click here"
      MEMBERS RIDE
      99 SILVERADO
      WHEEL FLIP
        This noise is very loud and comes from the timing belt side of the engine so i don't think that noise is coming from there.
        Wouldn't a spun bearing give me a knocking sound?
          I 2nd the spun bearing. That's what mine sounded like before the knocking started.
          psn: KoRn_LuVr
            Yup that's what I was going to say.
              Spun bearing in the block or the head?
                Also why does the car have no power at all? A bearing wouldn't cause loss of power would it?
                  How's your timing belt tension/static timing? Also your compression?
                    Sounds like a bearing in the block if im not mistaken. That sucks!!!! That motor looks so clean
                    Bought from:AbsurdNY,92smokeaccord,cb7inct,nevi325,xkjnboix,cb 7resurrector,JoshM
                    MRT: http://www.cb7tuner.com/vbb/showthread.php?t=203451
                      have u taken the timing belt cover off to see if it was slapping the cover cause thats what it kinda sounds like to me
                        Motor seized
                        fuck my life
                          I found out the hard way that h23's suck!
                          after 6 of them, unless your gunna rebuild them, they are crap stock!
                          MadLab Racing
                          Southern Maryland
                            So what would you reccomend i do? I want a working car i don't care THAT much about preformance so long as it runs good.
                              Well... You could get a stock F22 for a few hundred if you wanna call it quits with that H23. That is a full H23, correct?
